Transmission Slip
RE: Transmission Slip
well yeah. so the "not pumping fluid in the tc" applies to all. but how do i know if its a torqueflight type trans? iv slept in my truck when i went to florida and had no probs after bout 5hrs of sleep with the air on.
i let it idle in the mornin for bout 3-5 mins and i have no prob. just want to know before i end up having to buy a new one. "please let it break so i can convince my girl that i need the ats tranny"
mine has never done that... there is a check valve in the lines that is supposed to keep the fluid up in the converter & cooler to prevent the drainback into the pan. Go test drive another new one and see how it acts... I can almost guarantee you it wont act the same as your truck. your dealer is trying to dodge the problem.
on
ORIGINAL: cookie_monstr
In my 2006 owner’s manual on page 263 it has a few words about how the tranny will seem sluggish the first few second of operation after going in to gear due to some of the fluid draining out of the converter, its normal and will not hurt the tranny. Also the converter will fill with in 5 second of shifting out of Park in to any gear. IIRC a rebuilder over on the Diesel Ram Forum showed a photo of what happened to one person who left his truck idling in Park for I think it was 8 hours maybe less, maybe more anyway the damaged and broken parts sure did not look pretty and I bet the rebuild bill wasn’t either.
Like I said in on of my post above, mine will do it but I notice it more when it’s cold out side or if it has sat for several days. IMHO this is one more reason I want to switch my trans to Amsoil ATF fluid as it flows much better and holds up better then Mopar ATF does. I just remembered that I read of a person who said his TC would drain the fluid out of it in like 5 hours. It is also possible you have a trans that is not right and needs to be looked at, so if your dealers will not do any thing then I hope you have another one close by you can go to and see what they have to say.
Oh it must be nice to want it to break so you can go spend $5,000.00 to get an AST Tranny.
