Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
Oil Change
Old Apr 10, 2007 | 09:21 PM
Bixby76's Avatar
Bixby76
Default Oil Change
10w30 or what? I thought it said something different in the owners manual. What do you guys use? Where do you get the filters from? I know I have seen one with a nut on the bottom of easy removal.
Thanks.
Old Apr 10, 2007 | 10:04 PM
MADDOGC5's Avatar
MADDOGC5
Default RE: Oil Change
ORIGINAL: Bixby76
Thanks.
i believe the manual recomends 0w40 mobil 1 synthetic only
Old Apr 11, 2007 | 03:20 PM
QUICK_SILVER's Avatar
QUICK_SILVER
If you don't use Mobil-1...you'll VOID the warranty. And it doesn't take a even amount of oil. Be sure to have a Viper Mech. change it for you the first time and he'll tell you how much.
Useually they take a little less than 10-qts.
Quick
Old Apr 11, 2007 | 04:18 PM
CarGuyOhio's Avatar
CarGuyOhio
A little less that 10 quarts is sort of right, but to be exact it is 8.5 quarts if you change the filter, which you should always do. I also run M1, 10W-30. It is possible they changed the weight from year to year. If you have a 2004 it is 10W-30 for a very wide temperature range. I think it is lighter if it gets very cold, like 0F, I never worry about that as I do not drive it in the winter and I know Quick lives in perpetual sunshine.For 05 and 06, I can not confirm. Check the cap, if not on the oil cap then it will be in your manual.
Also check out the DIY post, I have a oil DIY for the SRT Ram posted amoung a few other items.
