Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
help with electrical
Old May 18, 2007 | 01:16 AM
bigmac73's Avatar
bigmac73
Default help with electrical
my heads lights come on with the switch off and also when i push in the clutch also when i turn on the headlight switch they some times flash off and on like some body is hitting the alarm button but at the same time i lose all lighting interior and exterior the dealer says they cant get the truck to replicate the problems when i take it to them any ideas or is it possesed with a demon
Old May 18, 2007 | 02:41 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: help with electrical
I would just start with the easiest thing, replace the switch.
Old May 18, 2007 | 02:22 PM
bigmac73's Avatar
bigmac73
well the problem is the dealers wont really do anything unless they can get it to act up i guess good old fashion trouble shooting dosent exsist anymore if they dont no codes on their computer they are lost
Old May 18, 2007 | 04:37 PM
iwantansrt4's Avatar
iwantansrt4
Yeah. I think it's your switch. Also look to see if your positive wire is touching ground.
Old May 18, 2007 | 06:13 PM
CarGuyOhio's Avatar
CarGuyOhio
Well if it is the switch it should be easy to figure out, for you that is. Just disconnect it and go for a drive. If all the things you said are happening does not happen, then it is probably the switch. From there you would have to convience the dealer for a warranty replacement or just buy one.
