Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
front hub breakage
Old Mar 8, 2008 | 11:28 AM
wdtvb's Avatar
wdtvb
Default front hub breakage
has anyone had the very frighting experince of taking a fast left hand turn with a dodge ram srt 10viper from 2004 and the front hubjust behind the brake disk broke or cracked in two? the only thing which held the wheel in place for a few minutes was the brake caliber. It is a hardened forging with a splined hole for 4wd which is not used on a 2wd. the question is why didn't dodge make it solid??and now there is thousands of $ damange on it?
Old Mar 13, 2008 | 12:27 AM
spaz_22's Avatar
spaz_22
Default RE: front hub breakage
...becuase your bearing was probably bad, and you never replaced it? this is why you should check your front end every oil change and check for loose parts...
