Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
Help! Dealer Inquiry!
Old May 17, 2004 | 02:27 AM
HemiGuy25's Avatar
HemiGuy25
Default Help! Dealer Inquiry!
I took deliver 3-19 and was not notified of the re-call. My dealer did not call or even say anything and since I have the only srt-10 in the area not sure if they will. What should I do? I heard it was only for engines built from sept 15 to dec 31st engine build. Is this true and where does this state when it was built?
Old May 23, 2004 | 03:37 PM
3_SRT_10s's Avatar
3_SRT_10s
Default RE: Help! Dealer Inquiry!
HemiGuy25,
I have 3 SRT-10s and only the one with the earliest VIN number was affected by the recall. The early models have the wrong sticker on the drivers door that identifies them with 17" x 8" wheels, instead of the 22" x 10" whells. If the dealer didn't call you, then itsnot likely your SRT-10 is affected. My truck that had the work done, turned out not to need it, and then after a week of driving it the harmonic balancer came apart becasue the dealer forgot to bolt it back on.
Old May 24, 2004 | 05:50 PM
HemiGuy25's Avatar
HemiGuy25
Thanks I hope I do not need the recall. I have one of the earlier models cause I remember the correct tires size sticker coming in the mail cause the door sticker says 17x8. You have 3 srt-10'3. the third is red? whats your favorite? My truck is black.
Old Jun 14, 2004 | 06:22 PM
lvd2340's Avatar
lvd2340
Here's the info on SRT-10 recalls:
Recall #D06
2004 (DR) Dodge Ram SRT-10
NOTE: This recall only applies to the above vehicles that were built through
January 16, 2004 (MDH 011622).
Customer Satisfaction Notification No. D06
Tire, Rim and Inflation Pressure Information
Subject:
The Vehicle Certification Label on about 500 of the above vehicles does not list
the appropriate tire size, rim and inflation pressure information. While the tire and
rim sizes shown on the label comply with Federal regulations, they can not be
mounted onto these vehicles without replacing additional components.
Repair:
Vehicle certification information correction label overlays will be mailed to
owners known to DaimlerChrysler for the owners to install (or for installation by
their dealer if preferred).
Recall #D192004 (ZB) Dodge Viper
NOTE: This notification applies only to the above vehicles equipped with an 8.3L
V-10 engine (ā€œZā€ in the 8th VIN position) built through January 31, 2004
(MDH 013100).
IMPORTANT: Many of the vehicles within the above build period have already
been inspected or repaired and, therefore, have been excluded from this
notification.
Subject:
The camshaft sprocket retaining bolts on about 1,200 of the above vehicles may
not have been properly tightened. A loose cam sprocket bolt can back out and
cause significant engine damage.
Repair:
The camshaft sprocket retaining bolts must be tightened to the proper specification.
