Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
Another new guy with questions
Old Jan 25, 2007 | 01:22 PM
Streetgang's Avatar
Streetgang
Default Another new guy with questions
Hey Folks,
I pick up an 05 Srt 10 Quad next week.It was a dealer demo.It has 14,000 miles.I have read the forum pretty closely.Other than the vibration problems which seem to be the biggest headache is there any other issuses that I should make the dealership aware of before I take delivery.The day I test drove it ....It was somewhat wet...I didn't get over 40 mph.
Thanks----Bill
Old Jan 25, 2007 | 02:05 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Another new guy with questions
Have them check the bolts on the crank pully, the can come loose. Just have them torque them, I also check them when I change my oil. 110-120 FT/LB.
Also check the door seals, near the bottom of the windshield area. When you open the door it catches the seal and rips it. There is a new design that fixed this and is covered under warranty.
Make sure the clutch is not slipping!! You maythink it still has warranty, but the clutch is part of the 1/12 limited warranty!
Not that it matters to much, but if any of the rubber stubs on the pedals are tore off they will also replace the pedals under warranty.
I think there may be some TSB or something with the crank sensor as well. Have the dealer give you all the TSBs
Old Jan 25, 2007 | 09:56 PM
QUICK_SILVER's Avatar
QUICK_SILVER
ORIGINAL: 94rt10ohio
Most of these problems were on our '04's. They seemed to figure it out by the time the Q/C came-out. Just make sure that your bands in your auto/trans. are not slipping.
Your auto/trans. is your "Weak-Link" be careful when you start modding her.
Quick
Old Jan 26, 2007 | 12:03 AM
DRamSrt10's Avatar
DRamSrt10
my truck is '04, so far it seems dont have any problems at all, only problem i have is wheels vibrating, i believe it probably have been from pirelli tires that's all
