2000 Ram 1500 hard to start........
Old Sep 19, 2007 | 01:27 PM
Big M Motorsport's Avatar
Big M Motorsport
Default 2000 Ram 1500 hard to start........
Hey guys, I'm having a problem with the van agian. It will start right up in the morning or right after you shut it off. But, if it sit's for more than a half hour or so its hard as heck to start and it is really rich when it does fire up. I was thinking maybe it was the temp sensor. What do you all think?
Thank you, Marc
Old Sep 19, 2007 | 02:06 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: 2000 Ram 1500 hard to start........
Ditto on the temp sensor. The one for the PCM though, not the one for the gauge.
Old Sep 19, 2007 | 03:00 PM
Big M Motorsport
Would this be the one right behind the alt.? Thanks
Old Sep 19, 2007 | 04:17 PM
stev's Avatar
stev
My van had this very same problem. It ended up being the ignition coil was flaky.
Old Sep 19, 2007 | 04:46 PM
Big M Motorsport
Thanks stev. I was thinking that too. Alloro helped me out a month ago when my van quit running. I just change it. But not going to rule it out. The one I replaced it with was only two months old. What could be eating these coils so fast?
Old Sep 19, 2007 | 05:02 PM
alloro's Avatar
alloro
ORIGINAL: Big M Motorsport
Excessive spark gap at the plugs or cap/rotor, spark jumping to ground, bad voltage regulator, 8mm plug wires instead of 7mm ones.
Old Sep 19, 2007 | 05:04 PM
alloro's Avatar
alloro
It's the 2-wire one (yes, usually behind that alt.) The single wire one is for the gauge/idiot light.
