B350 Ram Van Rattle
Old Feb 5, 2008 | 10:58 PM
lmmzr's Avatar
lmmzr
Default B350 Ram Van Rattle
I have just replaced the transmission mount and sway bar links hoping to get rid of a rattle that happens when I go over any size bump at any speed (mostly slower than 45mph). It's like a machine gun - there are about 6 rattles in about 2 seconds. The deep clunking rattle travels through the frame making it harder to pinpoint. Wish I could strap myself under the van and see what was going on!
Thanks so much for your help!
Old Feb 6, 2008 | 02:39 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: B350 Ram Van Rattle
Does it happen when the front wheels, back wheels, left wheels, or right wheels go over the bump?
Sometimes the protective cover on the top half of a shock will break loose from the shaft and cause a rattle. Does it still do it if you ride the brakes while going over a bump? If not,the anti-rattle springs could be missing from your front brake pads. Check all of your exhaust clamps for looseness. Bang on the catalytic converter, sometime the honeycomb inside breaks and will rattle around.
Old Feb 6, 2008 | 10:04 PM
landyacht318's Avatar
landyacht318
One of my front end rattles was the brake pads rattling around inside the brake caliper. It would dissappear when using the brakes. Hammered down the tangs a little to remove slop.
A current rattle of mine is that the strut rod bushing looks fine but I can grab the rod and easily move it with my hand till I hear a metal on metal sound. New ones have been ordered.
