o2 ram van 46re trans band adjustment
Old Feb 7, 2008 | 09:43 PM
ronsaun's Avatar
ronsaun
Default o2 ram van 46re trans band adjustment
where can i see pictures and or specs on theweb forfor adjusting my bands?
Old Feb 8, 2008 | 07:51 PM
stev's Avatar
stev
Default RE: o2 ram van 46re trans band adjustment
I forgot myself.[:@] There was a posting about this sometime ago. Try the search option for the Van forums.
Old Feb 8, 2008 | 07:56 PM
stev's Avatar
stev
Oooops! It's not here at this Dodge froum, it's at the other one ...
I'll cut-n-past my answer from the other place here so as others can search for it too! [&:]
--- clip in ---
ATF+4 if you don't do any towing. ATF+3 with Lubegard if you're towing with the van.
If you're going to spend the time draining out the fluid, cleaning/replacing the screen and putting in a new filter, you may want to check the Kickdown band screw torque and the Low-reverse band as well.
1995 and newer for the 36RH, 46RH and 46RE tranny.
Kickdown band ....... Tighten to 72-in-lbs, then back off 2-7/8 turns.
Low-reverse band ... Tighten to 72-in-lbs, then back off 2 turns.
1995 and newer for the 32RH and 42RH tranny.
Kickdown band ....... Tighten to 72-in-lbs, then back off 2-1/4 turns. (not for 42RH)
Low-reverse band ... Tighten to 72-in-lbs, then back off 4 turns.
Torque specs
Automatic transmission band adjusting screw locknut ... 30-ft-lbs
Automatic transmission pan bolts ... 96-in-lbs
WARNING ... When scrapping off the old tranny gasket, don't mare the aluminum surface.
This service of fluid, screen filter and band adjustment is required maintence every 30k miles. Although, people neglect doing this until about 80k miles when issues happen.
It's really not a hard job to do, only messy if you've never done a Ram Van before.
Old Feb 12, 2010 | 04:35 PM
02 Ram Van 1500's Avatar
02 Ram Van 1500
Is the rubber coated metal pan gasket reusable? There is a stamping on the pan saying to use a reusable pan gasket.
