Stalling
Old Feb 12, 2008 | 03:15 PM
Sirgroovy's Avatar
Sirgroovy
Default Stalling
Hi everyone,
I recently bought a 1992 Dodge B250 Mark III, it has a 5.2L 318 and for the first 2 weeks it ran like a champ, I drove the van from colorado springs to great falls montana and back she ran wonderful no issues at all.I took the van to a self serve car wash and thats when the problem started with the stalling, it seems especially prevalent when turning, is it possible something shorted when i washed the van and thats causing my trouble now, or is it just a coincidence>
Old Feb 12, 2008 | 06:29 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Stalling
If you just washed the outside it's probably coincidence. If however you washed under the hood, you could've removed some grime that was coating a wire and preventing it from shorting. You could've also gotten water in something that is fairly sealed up and is justtaking a while to dry out. The water could be swishing around in there causing an intermittent short whenever you corner.
Old Feb 15, 2008 | 07:25 PM
stev's Avatar
stev
I would check the coil, cap-n-rotor and the ballast resistor.
If it happens while turning, it's possible water is trapped in what-ever-it-is that's causing the problem too. Look around under the body and chassis too.
