Transmission oil cooler lines in a 92 b350
Old Mar 21, 2008 | 11:41 AM
B350Boy's Avatar
B350Boy
Default Transmission oil cooler lines in a 92 b350
So i just bought a b350 from a bud for 400 bux its in decent shape with one problem being that when i was putting it up on my trailer to tow it home, either the sending or returning oil cooler line burst due to rust. I called up my local dodge dealership which only got me as far as now knowing that dodge dosent even make that part anymore. What should I do, one of the gentlemen in service suggested cutting the bad part of the line out and replacing it with a rubber fuel line type hose... just hoping that someone else around these fourms has had these problems and knows how to fix.
Thanks,
MAtt
Old Mar 21, 2008 | 11:44 AM
B350Boy's Avatar
B350Boy
Default RE: Transmission oil cooler lines in a 92 b350
Forgot to mention its got the 318 5.2l but dont know what transmission
Thanks again
Old Mar 21, 2008 | 03:01 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
You can buy the steel lines and a bender from an auto parts store and make your own. The rubber hose is a good patch job idea, but I wouldn't replace the entire cooling line with it.
Old Mar 23, 2008 | 11:38 AM
corgimom's Avatar
corgimom
I have a 8 inch segment replaced with hose. I did it so I can pump out the tranny fluid to change it. It has been that way for 3 years with no issues.
