Fuel Tank Removal for 98 Ram Van
Old Apr 4, 2008 | 01:47 PM
swotrb's Avatar
swotrb
Default Fuel Tank Removal for 98 Ram Van
I need to replace the fuel pump in a 98 Dodge Ram Van with a 35 gal side tank. The problem is trying to remove the tank strap nuts, their studs are like 6"-8" long, too long for my deep well sockets and theirs not enough room for a wrecth,
Question: is their a specialtool needed to remove the tank bolts? any ideas on removing the will be helpful. Thanks
Old Apr 4, 2008 | 11:07 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Fuel Tank Removal for 98 Ram Van
Can you get a crows foot in there? If you've never heard of these, here's a link just to give you an idea of what I'm talking about.
http://www.northerntool.com/webapp/w...2174_200012174
Old Apr 5, 2008 | 01:49 AM
swotrb's Avatar
swotrb
Thank youfor your time and help, I thought about thatuntill I found something that might work better, Harbor Freight has a set ofGO-THRU SOCKETS that will allow the stud to go thru the socket and ractchet end. Hopfully that will work.
Old Apr 5, 2008 | 12:39 PM
alloro's Avatar
alloro
The extension in their set is only 3" long. Will that be enough length to get you in there?
(Keep it clean guys!)
