No blower speed-full size Ram.
Old Jan 27, 2004 | 11:16 PM
71_deputy's Avatar
71_deputy
Default No blower speed-full size Ram.
ram van 1500- probley the same with other full size vans.</P>
if you have only high blower speed for heat- chances are the heater resister block in the box is bad. The unit has a thermo diode in series with the resistors that grounds out the motor.</P>
the high speed is controlled by a different relay in the engine pdc.</P>
may also be a bad dash blower switch- but this thermo diode is like the one in a hair dryer- once they over heat- their done!!!!!</P>
John</P><edited><editID>71_deputy</editID><editDate>38013.845</editDate></edited>
Old Jan 28, 2004 | 01:59 AM
caravansasleepr's Avatar
caravansasleepr
keep in mind the wirring circuit for the chrysler vans has an over load bypass allowing you to still use the the heat and A/c as mentioned in the previous message the cause is a faulty blower motor resistor if not then your wiring is bad these circuits are simplistic in design and extremely easy to diagnose Caravansasleepr
