need help taking off inside panel of cargo door
Old Jun 29, 2008 | 10:24 PM
DaDodge's Avatar
DaDodge
Default need help taking off inside panel of cargo door
Can someone walk me thru how to take the inside panel off the side door? I have a dent in the door that can be rubbed out from the inside. My van is a 2001 B2500. Thanks.
Old Jun 30, 2008 | 08:35 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Default RE: need help taking off inside panel of cargo door
It should have push pins that hold the panel on, just carefully lift the panel away from the metal. You may need to remove the handle trim first.
Old Jul 2, 2008 | 04:11 AM
IGadget's Avatar
IGadget
You can carefully pop the pins with 2 flathead screwdrivers, but you would be best off buying a panel tool (about $15) or if you dont mind scratching things up a lot, you can use the long flatish side of a crowbar that has a nail pulling notch. basicly it is a wire clip that is slid into the cardboard backing of the pad, and through a round hole in the sheetmetal of the door. The pins push in to re-secure. Check carefully for a screwed on section (possibly lower third) before you start.
