Help, need running boards or steps
My B2500 sits so high that I need either steps or short running boards to get in or out. I'm sure someone has solved this problem. I went to Chux's Truxs today to have a set of "universal" steps put on, and they wouldn't fit. The only running boards they had went full length, wheel to wheel, and they cost $375 plus $280 to install. I just want to cover the driver & passenger door areas nothing fancy just functional. Thanks for any and all help.
You didn't specify a year so I use 2000 just to get an idea. I trust you're looking for something like this?
http://www.jcwhitney.com/GARAGE-PRO-...1907_10101.jcw
Dodge Conversion Van OEM running boards can be found here.
These will work even if the van isn't a conversion.
http://cpcparts.com/products/subcat....ound%20Effects
Click on the "Dodge Van Aluminum Running Boards"
They even have the OEM rear bumper pad kits too.
