97 RAM Van 3500 Throttle Position Sensor??? - Code 24
Old Aug 9, 2008 | 06:55 PM
mgr1's Avatar
mgr1
Default 97 RAM Van 3500 Throttle Position Sensor??? - Code 24
I have an error code 24, which, according to a friend, is the Throttle Postion Sensor (TPS). Where would that be located on a 97 RAM Van 3500, 5.9L engine? We may have some tranny problems, the van seems to get "confused" between 3rd gear and overdrive, bouncing back and forth a bit (but most of the time no problem at all). Occasionally, it will lurch even at lower speeds (very intermittent also), so we thought it was related to a fuel problem. So, help on the location of the TPS and help on diagnosis would be GREATLY appreciated.
Old Aug 9, 2008 | 09:11 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
It's mounted to the side of the throttle body opposite of the side with the throttle cable.
