Tranny fluid What kind to use?
hello,
Well a guy was helping me with my van and put in a quart of dec/merc fluid in the transmission. Is this good or bad? Will the fluid cause problems / damage to the transmission?
Van 1990 b150 3.6L v6. What is the recommended trans fluid?
thanks,
thanks,
Though 1 quart of mercon probably wont hurt the tranny, the only fluid which should be put in these trannies is ATF +4, +3 (7176)no longer available.
Why was it a quart low?
Consider dropping the pan, changing the fluid( about 4 quarts), and filter.
there was a leak at the pressurized hose which connects to the radiator. Both inlet and outlet hoses needed to be replace. Most of the fluid came out. I suppose he put more then one quart of fluid.
