Gas fill up cuts off before full
Old May 4, 2009 | 08:33 AM
davedawe's Avatar
davedawe
Default Gas fill up cuts off before full
1999 dodge ram 3500,318
gas level at 1/2 or 3/4,try to top up,filler cuts out at normal flow.
why? Thanks
Old May 4, 2009 | 12:31 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
1. If the fill station has their pumps set to fast. (Excessive splashing within the filler tube can cause this to happen.)
2. The filler tube on the van is rubber and could be kinked, causing a flow restriction.
3. The tank might indeed be full and your gauge is not accurate.
In the case of numbers 1 or 2, swinging the nozzle left or right a bit when filling often will eliminate this problem.
