Lug pattern???
Old Mar 14, 2005 | 12:39 PM
88RamVan's Avatar
88RamVan
Default Lug pattern???
Im am looking for rims for my 88 Van.When I am looking I see rims for the newer vans and trucks.It is hard to find rims for the Van.My quiestion is will the lug pattern be the same from my 88 up to the mid 90's and newer?
Thanks for any help.
Old Mar 16, 2005 | 02:45 PM
88RamVan's Avatar
88RamVan
Default RE: Lug pattern???
[sm=feedback.gif]
Old Mar 18, 2005 | 05:10 AM
Dodge Balls's Avatar
Dodge Balls
Dodge made several patterns, but the two most common seem to be the 5 x 100mm and the 5 x 4.5"(114.3mm). I dont' recall which vans had which patterns. Someone else may be able to give you more info on that. The easiest thing to do would be to either carefull measure from the center of one lug across the hub to the center of one of the other opposite lugs. You could also go to any local tire store and they should be able to tell you by looking at it. This should give you a starting point in your search. Good luck.
Old Mar 18, 2005 | 05:13 AM
Dodge Balls
I just remembered that I too once owned a 1988 Plymouth Voyager and I remember that mine was the 5 x 100mm which leads me to believe that yours too would be the same. The was less choices back then and I personally never came across any other pattern on the same year vans. It would still be best to measure or have someone else measure for you.
Old Mar 18, 2005 | 11:26 AM
88RamVan's Avatar
88RamVan
Thanks for the input I will try measuring it and see what I get.Once I figure it out I will post for future refrence.
Old Mar 18, 2005 | 02:43 PM
Danko's Avatar
Danko
FWD Caravans have nothing to do with the RWD Ram vans which have had 4.5" diam. since the Conastoga days. You can actually put some pretty big meat on the stock rims if you do not go to the very low profile series tires.
