1995 RAM VAN 5.2 Idles fine but when put in drive begins to miss a little
When you start it it runs fine and it drives fine,,,,but when it idles in drive sometimes it feels like it going to stall,,,,,,just for a brief second...but keeps running...................not related but another issue is when taking off in the van i hear a clunk in the passanger side wheel area...and it happens everytime i take off
you guys are great helped me repair all my electrical problems hope we can walk thru this
The stalling issue could be a dirty IAC valve. Read this how to clean the IAC valve post by stev.
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
The clunking could be a lot of things, a bushing, a ball joint, loose caliper, etc. That's something where you're just going to have to get under there and start pulling and pushing to find what is worn.
Thank you again for all your help...you got all my electrical working now i am bothering you for other problems......i will clean that out and see if it helps.( i am sure it will)...as far as the noise in the front...i just put all new brakes in the front...and all the front brake parts are all tight....and it has been making the noise since i got it....i feel it something in the front end. ...is it expencive to replace ball joints and etc on the front end???/can i do it and have it aligned?????.......can i buy parts at like o'riely...or kragen???????
Average, yes and yes, yes.
