Two quick questions....
Old Jun 6, 2009 | 11:35 AM
DieselGMCvan's Avatar
DieselGMCvan
Default Two quick questions....
First, I have a 1994 B250 Ram Conversion van...
My first question was what type of trans fluid should I use in it? (I remember someone saying don't use xxxxx type fluid, stick with xxxxx type and you'll be OK).. I don't remember the types now and can't find the thread either..
My second question involves the temp gauge and the temp sensors. The temp gauge on this van doesnt work, and I know it has 2 sensors - one for the ECM and one for the gauge (both are down on the front of the intake manifold). I just dont know which is which. Both are kinda a pain to get to... but one has 2 wires and the other has 1 wire. I have a spare of each from another van and was wondering which one to swap out..
Thanks for any help, Spenser
Old Jun 6, 2009 | 12:39 PM
landyacht318's Avatar
landyacht318
ATF +3 if you can still find it, or more likely ATF+4 which is Synthetic. Don't use anything else or trust any tranny shop to use the right stuff.
The 2 wire is for the ECM. 1 wire for the dash gauge..
Goto rockauto.com and look at the photos
Old Jun 7, 2009 | 10:08 AM
DieselGMCvan
thank you!
I bought this van for $125 with no heads on it... it's come a long way and is almost finished!
-Spenser
Old Jun 7, 2009 | 10:20 AM
DieselGMCvan
Actually, I do have one more question... I need an exahust flange for the end of the pipe that bolts up to the driver's side manifold, and needed to know what size it is. I think it's 2 1/4", but i'm not 100% sure.... (I think both pipes from each manifold are 2 1/4", and once they come together they go to a 2 1/2" pipe from there on back)
Thanks again, Spenser
