1999 B1500 - P0505 Idle Problems.
Old Aug 30, 2009 | 01:06 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by Mobile Auto Repair
First this is a big NO-NO, the mechanic did not fix anything he just broke your newest IAC motor.
That would depend on how he adjusted the idle manually. He might have adjusted it simply by opening the butterfly slightly.
Old Aug 30, 2009 | 04:29 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
A pic of each side of the throttle body would help him and us to know.
Old Aug 31, 2009 | 05:21 PM
mcubed4130's Avatar
mcubed4130
Sorry all, my window regulator seems to have given up the ghost with the window down over the weekend, so Van is back in a shop... and now I'm being told 3+ weeks on back-order for window regulators... sigh... anyway, haven't had time to do the tests you all asked me to do... I'll keep you guys posted, thank you for all the help so far!
And if anyone knows a source for a 1999 Dodge Van drivers side window regulator (power windows) - please let me know, by PM.
-M3
Old Sep 1, 2009 | 08:41 AM
kev2's Avatar
kev2
Mobile Auto Repair : your trick blocking iac off ....my thinking correct me if wrong- with iac closed eng will go rich, pcm will react- want to go leaner- ck tps see at "idle" open iac?
that is issue IAC is full open when connected.....
i wonder if pcm is driving iac at all or problem with wiring pcm-iac ....
Old Sep 1, 2009 | 07:31 PM
Mobile Auto Repair
Yes the PCM will try to open the the IAC more as you are shutting down the IAC opening in the TB. Some how once you stall the engine with the IAC in full open and then disconnect the battery for minimum two minutes and then turn off the key, reattach the battery, and turn the key on for 5 seconds that the PCM resets the IAC to the full closed position and relearns the IAC control.
Will this help the OP situation, I would hope it would, if not and the IAC stays in full open condition then I would trace the IAC wiring and then check continuity between the PCM harness connector and the IAC connector for no short to engine ground and that the wire is fully intact. If then that the wiring is good then I would believe that the PCM may be faulty, if there are no other codes coming up.
Old Sep 1, 2009 | 07:55 PM
kev2's Avatar
kev2
then just seeing it go closed will be positive showing pcm is still able to control it
Old Aug 3, 2012 | 12:00 AM
mcubed4130's Avatar
mcubed4130
FYI... I gave up took it to a shop - paid waaaay too much money... and...
It really was a defective computer. Idling perfectly again.
-Michael
Old Aug 3, 2012 | 03:58 AM
DoubleWasp's Avatar
DoubleWasp
Our computers are in probably the worst place possible. It's no surprise that failures are so common. Glad to hear you reached resolution.
Old Aug 3, 2012 | 08:14 AM
Mobile Auto Repair
Glad to hear you got the problem found and corrected.
Old Aug 3, 2012 | 12:25 PM
mcubed4130's Avatar
mcubed4130
Thanks for the good will from both of you - and I'm happy to see I finally get email notifications from this forum now! :-)
In the mode of - "probably the worst place"... I think the low speed fan controller is up there in that game as well... every single Winter... that low speed fan controller burns out. Gee... it's in the hvac intake and it's a resistor pack that generates heat...
Well and as of this morning new Check Engine light ( Trans has been acting funny since it was serviced - time to find out what new code I need to deal with ).
Thank you all for your help!
-Michael
