Brakes are soft
Old Sep 11, 2009 | 03:30 PM
cudajim's Avatar
cudajim
I did bench bleed the master, it made a big mess but no air was left in it. I then put it on the van and bled quite a bit more all the way around. (I use the wife, she has a sturdy leg)
Alloro mentioned the ABS valve could be bad. I guess I will look into it this weekend.
Old Sep 14, 2009 | 12:38 PM
cudajim's Avatar
cudajim
Yup I did.
Old Sep 14, 2009 | 12:40 PM
cudajim's Avatar
cudajim
So I keep replying to this but it shows up elsewhere.
Yes I did bleed the master as well as the entire system - several times.
Old Sep 22, 2009 | 07:19 PM
cudajim's Avatar
cudajim
I also took the van to a "Brake" guy and he said it stops just fine. I told him he's crazy because I know better. It used to stop way way better..... it's like it's not grabbing the fronts.
Old Sep 22, 2009 | 08:22 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The problem is with the rears, the fronts are okay. If the rears were working and the fronts were not, you'd be skidding at almost every stop.
Old Aug 30, 2011 | 10:48 AM
RAMtough98's Avatar
RAMtough98
Originally Posted by Leeann
Quick question: did you bench bleed the master cylinder before installing it on the van?
of course you have to ench bleed any new master cyl
Old Aug 30, 2011 | 01:40 PM
cudajim's Avatar
cudajim
Yes, the master was bench bled till no more bubbles came out. I then installed it on the van and bled the system with a helper over and over again (fronts and rears).
Old Aug 31, 2011 | 12:48 PM
RAMtough98's Avatar
RAMtough98
what are they doing?
Old Aug 31, 2011 | 02:38 PM
alloro's Avatar
alloro
Read post #1 on page 1 of this thread.
