hi i have problems van ram 250
Old Oct 6, 2009 | 05:33 PM
panchoelpescador's Avatar
panchoelpescador
Angry hi i have problems van ram 250
i have trouble with spedometer of van ram 1991 the needle speeds is good but dont move the meter . anticipate thanks
Old Oct 6, 2009 | 06:50 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Dodge Ram van section,
FF
Old Oct 6, 2009 | 07:14 PM
Horton's Avatar
Horton
If you are saying the odometer doesn't move, I had the same problem on my 90 B250. I bought a speedo cluster off ebay for 39 bucks, installed it & odometer started working. It's usually in the cluster, but someone may have another suggestion.
Old Oct 6, 2009 | 08:11 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Yes you can replace the cluster. But if you would rather not, the problem is a small plastic gear inside the speedometer assembly that strips.
On this page: http://www.carradio.com/speedometer-gears.html
Go down to: FORD, DODGE and CHRYSLER
20 TOOTH ODOMETER GEAR #10-016 $28.00
That is the gear you need to replace in order to get the odometer working again.
