72 tradesman...proper procedure for...
Old Feb 1, 2010 | 06:31 PM
craig3x's Avatar
craig3x
Default 72 tradesman...proper procedure for...
I drained and replaced the tranny filter (automatic). what is the proper procedure for refilling the tranny fluid?
Old Feb 1, 2010 | 07:13 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Pour 3-1/2 quarts of Dextron auto tranny fluid down the tranny dipstick tube. Run the engine, shift through all of the gears (foot on brake), then go 10 miles down a highway, turn around and come back. (Bring the tranny fluid on the drive with you just in case you need it, but you shouldn't.) Leave the engine running and check the tranny fluid level. Add 1/2 pint (1/4 of a quart) at a time until the level is up to full.
Old Feb 1, 2010 | 08:35 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
On adding fluid after a trans filter change I have a little trick I use, and that is to measure what was removed then add that amount of fresh back in. It works every time.
Old Feb 1, 2010 | 08:54 PM
alloro's Avatar
alloro
That works for you because you're meticulous in your maintenance. But for some, that method could prove bad if the correct amount of fluid was not in the tranny to begin with. Also, if it's the first time someone is changing the fluid since owning the van, the same doubt could arise.
Old Feb 2, 2010 | 02:21 PM
craig3x's Avatar
craig3x
thanks guys. All good advice
