Transmission Swap
Old Feb 21, 2010 | 03:58 PM
RussellRowell's Avatar
RussellRowell
Default Transmission Swap
Hello, I have a 36rh in my van and was wanting to swap in a 46rh so I can have over drive to help save on gas. Would this be hard to do? Will this include installing a different wiring harness and changing my diff gears? Any input is greatly appreciated.
Old Feb 21, 2010 | 07:31 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The problem you'll have is that the PCM doesn't contain the programming for OD operation. Most people use a 518 tranny for the swap to get OD. Here's a page telling you how to do it along with the parts you'll need.
http://www.transmissioncenter.net/SwapInformation.htm
Old Feb 21, 2010 | 08:34 PM
RussellRowell
Well I'm not 100%, but I think that article is for 1995 and earlier that already have the A-727 installed. I don't think the A-518 will bolt up where a 36RH was. I guess I'm stuck with the 3 speed which is depressing.
