rough idle and # 3 weak compression. new member
Old Apr 27, 2010 | 11:31 PM
soundmiami's Avatar
soundmiami
Default rough idle and # 3 weak compression. new member
I have a 2002 1500 conversation van with 60,000 m and I think I have a weak # 3. It shows about 90 psi while the other 5 are all about 120. but no smoke or or water in the oil and no ticking noises.
I have a engine light on for years the dealer keeps telling me is a minor vacuum leak which they haven't been able to locate even with smoke test. I went to an independent shop and they got a code of #3 misfire which is why I did the compressing test. Still...it seems kind of early for a burnt or sticky valve.
SO my question: They say the heads be pulled in the van. But it's a PITA just getting the plugs out for a compression test, I can't see getting the exhaust off and then torquing head bolts later on in such a confined space.
Nothing at Advance Auto in the how too books on the Ram 1500 and nothing on ebay either right now.
I really like this van. I sold my last Ram conversion van at 100,000 miles and always regretted it. (and it was running perfectly)
Any books, manuals or web sites would be helpful. Other than a little rough idle when hot the thing's mint and a great way to travel.
Thanks
Old Apr 28, 2010 | 10:57 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
What engine?
90 PSI is way too low, even 120 PSI is on the low side. You should be up more around 140 PSI.
If it's a vacuum leak then why is it affecting only one cylinder instead of all of them?
Old Apr 29, 2010 | 11:51 PM
soundmiami's Avatar
soundmiami
it's a 3.9 but I can't see how a vacuum leak could cause a misfire in #3 unless the whole system was running very poorly and #3 is just the weakest cylinder so it's failing most often. The old plug looks OK. BTW I did a complete 60,000 tune/ plug wires rotor cap etc. and TB clean including new gaskets with no improvement
Since the dealer couldn't find a leak with the smoke test, I'm not holding out much hope. I hate to pay another dealer another $90.
Any how-to books or posts?
Old Apr 30, 2010 | 11:03 AM
alloro's Avatar
alloro
There's not much else to do except pull the heads and do a valve job on them.
Old May 1, 2010 | 02:26 PM
soundmiami's Avatar
soundmiami
ok thanks
then to quote the queen of hearts "Off with the heads"
