New gUy here with a dumb question
Old May 6, 2010 | 01:16 PM
TheDirtySanchez's Avatar
TheDirtySanchez
Default New gUy here with a dumb question
Hello, I just got myself a 1992 ram 250 Van Mark 3, and I was wondering if the dome lights are suppose to come on when you open the drivers side door ? If I open any other doors they come on, but not the driver's side.
Old May 6, 2010 | 05:58 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Yes the dome lights are supposed to come on. The driver's door switch must be broken.
Old May 6, 2010 | 06:35 PM
Hillbilly Wheeling's Avatar
Hillbilly Wheeling
There should be a small button, on the door jam that springs open that turns that light on when you open the door, and when you close it, it turns it off. Its an old vehicle, so having that as a problem is pretty minor, but its nice to have everything working.
Look at the other doors, and press it in and out.
It might not even be there, only a hole or perhaps the guy took it off and bondo'd it.
Button can be on the back door jam, or the hinge side.
Old May 6, 2010 | 10:12 PM
battleaxe's Avatar
battleaxe
some people disable the driver side button, keeps the buzzer from buzzing when key is in ignition
Old May 8, 2010 | 02:26 AM
TheDirtySanchez
Ok the Button is there, it springs,buzzer works, but no light,all the other doors will turn on the lights but the driver side door won't ...funny ,thanks for the responce
Old May 8, 2010 | 01:52 PM
alloro's Avatar
alloro
Remove the switch and see if it has an extra wire on it. The driver's door circuitry is different than the other doors, because it not only turns the dome light on, but it turns on the key in ignition buzzer. If the light and buzzer circuits or tied together, then the buzzer would sound when any door was open.
The other alternatives is there is either a couple of isolation diodes on the driver's door switch circuit, or a relay. You might have to start tracing to find either one.
Old May 9, 2010 | 11:46 AM
TheDirtySanchez
Ok cool thanks 4 the responce...I got it...as I tried 2 take out the switch it started working ...it had a bad contact 2 the metal ...used a little WD40 and all is good. Thanks 2 all that helped.
