How do I get a raised roof off a van in junk yard?
I see a ton of raised roof vans in the junk yard. I want to know how I get a raised roof off a junked van, do I just cut it with a saws-all or is there a rule of thumb to use, like maybe cut an inch from the plastic/fiberglass all the way around.
Any special registry/insurance thing you have to do?
There is a piece of trim just above the roof gutters. Remove this, and you will see a piece of aluminum running all the way around with screws every 4 inches or so.
Remove all the screws. There will be some foam rubber trim between the roof and metal. This will be stuck. Wedges, flat bars, putty knifes,screwdrivers. Once I had to use a car jack inside with an extension to keep pressure on it while I pried around the perimeter.
There will be a lot of wires. With out all the foo foo velor and insulation, it weighs about 200 lbs.
Bring friends, and 2x4's.
