1996 1500 conversion van
Old Jul 6, 2010 | 12:31 AM
jaymichael's Avatar
jaymichael
Angry 1996 1500 conversion van
i have an 1996 dodge conversion van and my problem is that the van will cut off when i stop motion sometimes and recently its starting to shut off while in motion now but it starts right back up and i was thinking tune up but i was also informed about a pickup coil or pick up wire does anyone know about this problem that maybe able to offer me a solution ... In NEED of HELP ASAP ... THANK YOU
Old Jul 6, 2010 | 01:06 AM
stev's Avatar
stev
1) new plugs. Autolite AP 5224 (single Platinum works great!)
2) new cap-n-rotor. Get a set with copper/brass contacts. The aluminum are junk and flake and pit badly.
3) New ignition wire set. 7mm to 9mm size works great.
4) New ignition coil if it needs it. Possibly not.
5) Clean the IAC. Easy to do, just follow these simple steps ... https://dodgeforum.com/forum/dodge-r...n-the-iac.html
6) clean or replace PVC
7) new air filter.
After all of that, your van should not stall out after braking to a stop.
Old Jul 6, 2010 | 11:49 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
All 7 steps are good suggestions, but if money is tight I would start with cleaning the IAC valve and see what happens.
Old Jul 6, 2010 | 02:23 PM
jaymichael's Avatar
jaymichael
7) new air filter.
Thank you Much Steve how about a Pickup wire or coil does that have anything to do with it ?
Old Jul 6, 2010 | 08:23 PM
stev's Avatar
stev
Usually if the other items on the list have been resolved, then the ignition coil is something to look at. Also note, a weak battery or alternator can do this in a heart beat as well.
Take Alloro's advice and work from the least cost item to the more costly.
So, if a tune up of part hasn't been done in some time, tray that route.
Have you tried the turn the key trick three times for getting codes? these will show up in the digital mileage display in the lower left of the gauges.
