1992 Dodge B250 fuel pressure
Old Aug 1, 2010 | 05:11 PM
fmancinelli's Avatar
fmancinelli
Default 1992 Dodge B250 fuel pressure
Does anyone know the fuel pressure specs for a 92 B250? It is a 318 5.2
I have the gauge and checked it on the fuel rail at the schrader valve.
Just ignition on it reads 39 lbs. While running it reads about 35-36. Is it possible for a pressure regulator to be faulty and create erratic running while under load?
Old Aug 1, 2010 | 05:59 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
That pressure reading is right where it should be.
Old Aug 1, 2010 | 06:08 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Have you done a tune up on this van? Is the terminals on the distributor cap brass or aluminum? If the latter get a new one with brass terminals. What plugs are you using and how many miles are on them?
Also have you changed out the fuel filter? I believe on your van it is just in front of the right side axle inside of the frame rail.
