Fan Spun off
Old Aug 16, 2010 | 08:46 PM
Benreal1's Avatar
Benreal1
Default Fan Spun off
Ok the previous problem was a/c in the front blowing warm air I check the blend door and other vents all were good. still warm air so I decided the go to autozone get some 134a freon and added some of it. PSI was 35- 40 and when I goosed the engine the PSI went down added a little more and goosed it again and I heard a squeel. Shut the engine down to investigate and found that the serpitene belt was off and the fan on the motor was barely on the shaft and when I touched it it fell off and antifreeze is everywhere
Any help is appreciated
Old Aug 16, 2010 | 11:14 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
It sounds like your water pump blew.
Old Aug 16, 2010 | 11:51 PM
stev's Avatar
stev
Hey, if you are busy working in that area, change the T-stat to a 180.
