Where o' where is my fuel pump relay
Old Oct 7, 2010 | 01:30 PM
tenorbud's Avatar
tenorbud
Default Where o' where is my fuel pump relay
2000 Dodge Ram 2500 van, 5.9. Been having problems and need to check my fuel pump relay. My "UNDER THE HOOD" POWER DISTRIBUTION MODULE DOES NOT HAVE ANY FUEL PUMP RELAY INDICATED. The order from front to rear is: HVAC Blower Relay, Starter Relay, Trans relay, Air Cond. Clutch relay, and ASD relay. All theses relays are the same size and part number and easily switched around. Checked each one for response with 12volts and without to see if operation is good. They all check. Checking voltage back at my fuel tank, I found no 12v when key turned to on. So backtracking and wanting to test the fuel pump relay. Cant Find It!!! Book shows a larger square module, but I don't see one anywhere. Advance auto parts shows me a huge firewall mounted unit that I don't seem to have either. Help is greatly desired and needed. I don't have much hair left to begin with...
Old Jul 27, 2011 | 09:54 PM
Gr8lite's Avatar
Gr8lite
Where did you eventually find the fuel pump relay? I am having the same problem.....Thanks!
Old Jul 27, 2011 | 11:56 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
If it's not in the power box, then it's mounted to the firewall near the brake booster.
Old Jul 28, 2011 | 07:29 AM
Gr8lite's Avatar
Gr8lite
I have no relay tagged as "Fuel Pump" in the under hood power dist. box , or in the end of dash power box. There is no relay that we can see near the firewall by the brake booster. This is very confusing.... Thanks for all the help!
Old Jul 29, 2011 | 10:15 PM
offroadohio's Avatar
offroadohio
The relay is on the drivers side of the dash with the fuses. Thereare two small relays on the far left of the fuse panel. the top one is the fuel pump relay.
Old Aug 11, 2011 | 09:12 AM
Gr8lite's Avatar
Gr8lite
We have GO! Plugged rebuild ecu in , connected battery.........we have power! Primed pump w/ 3 turns of the key , fired right up!
Now that said , the Auto computer company in Florida , leaves A LOT to be desired in customer service. promises made , back talk with denial. As a matter of fact their website price was $199.00, on the phone tried to tell me it was $259.00! They said they would , and did honor the price. They told me the website was being changed as we spoke , that was 2 weeks ago , still $199.00 on website..........
All said and done...................Van is running ! Thanks for all the Great help , you've all been Super!
