Obsessive-compulsive preventative maintenace...?
Old Dec 1, 2010 | 04:46 AM
SweetwaterJoe's Avatar
SweetwaterJoe
Default Obsessive-compulsive preventative maintenace...?
Hi Folks,
Just joined and my first post. Great community of Dodge van folks. My story... I just purchsed a Sportsmobile Class B van conversion that was built on a 1995 Dodge 3500 van. It has 75,00 miles and was well maintained. I have read the horror stories of the fuel pump failing. It seems to happen right after folks fill their tanks.
I was going to buy a spare to keep in the van just in case. Then I thought I might just as well replace the pump so I can do it when the tank isn't full and its nice and sunny and warm outside. Knowing my luck I will be on some remote Forest Service road at night in snow when it fails.
Crazy idea?
Thanks!
Old Dec 1, 2010 | 08:07 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Good idea on replacing the pump module. Most here highly recommend replacing it with a Dodge OEM unit. There have been many whom have tried aftermarket pumps and had them fail fairly soon to immediately after install. Now that was a few years ago.
I and a couple of others are running aftermarket pumps in our vans and so far we have not had any problems. Mine is about 8 months old now.
That said no matter which pump you use I personally recommend keeping the fuel tank over half full at all times. This helps keep the pump submerged in the fuel which acts like a coolant to the motor which can get quite warm while running.
Old Dec 1, 2010 | 10:22 PM
wifesdaycarevan's Avatar
wifesdaycarevan
Welcome SweetwaterJoe,
I have found this site very useful too. About your fuel pump. I am running a Delphi fuel pump from Napa and have had no problem after the OEM failed with 120k on her. I have had it in for 3 yrs with no problems. Good Luck and by the way these pumps aint cheap either...nice dent in the pocket book!
Old Dec 3, 2010 | 09:39 AM
nibroc's Avatar
nibroc
replacing the fuel pump is a pita---on my 89 "factoy" customized van the plywood on the floor was screwed into the plastic gas tank--did i say it was a PITA?
