98 ram van 3.9 v6
Old Jan 27, 2011 | 10:24 AM
ayceeman's Avatar
ayceeman
Default 98 ram van 3.9 v6
cannot get van to stop stalling.. EVERYTHING replaced we thought would work... cam sensor, crank sensor, PCM(ouch).. flywheel,distributor,wires, plugs,starter,timimg chain..Etc 3rd PCM (computer) in 1 yr.. nothing seems to keep engine running.... appears it is sending a signal to fuel pump and distrib. to fire when the ignition is OFF resulting in mis-fire and flooding the engine .. also been told that NO aftermarket computer will work in this van ..HAS TO come from Dodge ??? help ..I own an AC business ...been down 2 months trying to fix thing
Old Jan 27, 2011 | 10:30 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Clean the IAC as shown at the following link. If cleaning it doesn't solve the problem then just replace it.
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Jan 28, 2011 | 06:47 PM
stev's Avatar
stev
Ah, you can get re-manufactured PCM/ECM computers for our vans. CARDONE is the most popular.
Old Jan 29, 2011 | 09:06 PM
stev's Avatar
stev
CARDONE info can be found here.
http://www.cardone.com/English/Club/...cs/default.asp
You will need to provide make, model and VIN number for a proper ECM/PCM unit for your vehicle.
