98 van 2500 overdrive
Old Feb 22, 2011 | 07:09 PM
devious1961's Avatar
devious1961
Default 98 van 2500 overdrive
mines out. can i just replace the tail section?
Old Feb 22, 2011 | 07:11 PM
landyacht318's Avatar
landyacht318
Could just be a solenoid or other electrical issue, not necessarily mechanical.
And if it is mechanical, I don't know if just the tail section is replaceable or not
Old Feb 22, 2011 | 07:12 PM
devious1961
switch turns light off and on, i dont know much else about automatics tho
Old Feb 22, 2011 | 07:57 PM
landyacht318
See if there are any stored computer codes for the overdrive solenoid/circuit. The OD light tells you nothing
Do a search for 'Key Dance' and learn how to pull codes from the computer without a scanner, or goto AZ or someplace else.
If there is a mechanical issue, the overdrive unit will send abrasive metal throughout the tranny and that means full rebuild.$$$$$$$$$$$$$
Old Mar 22, 2011 | 06:39 PM
devious1961
here my check engine light is burnrd out. had it checked getting codes P0740 and P0783. anyone have a clue to cuase i looked up 1 is torque converter lockup 1 is 3-4 shift(i know this lol)
Old Mar 22, 2011 | 06:43 PM
devious1961
just looked at stickys post. gonna try a fluid change.
