back door A/C install power inverter questions
Old Feb 24, 2011 | 01:25 PM
TheDirtySanchez's Avatar
TheDirtySanchez
Default back door A/C install power inverter questions
Im going to install a small 5000btu a/c in the back door, NOT window of my van, has anybody else here done this? It's rated at 500wts and somebody gave me a 600wt inverter would that be enough power?
here is a few pics of one installed in a ford
Old Feb 24, 2011 | 02:35 PM
landyacht318's Avatar
landyacht318
You will probably need a 2500 watt inverter capable of handling startup surges 1500 watts higher than that.
Your alternator will not be able to keep up 95% of the time and you will find yourself going through batteries like candy.
The AC in the back door is good for being parked when you have grid power or a generator. Unless you heavily insulate your van and park in the shade, it will only slightly make a dent in Florida's summertime heat.
Old Mar 1, 2011 | 10:47 PM
TheDirtySanchez
My Idea was...Duel battery isolator with a deep cycle battery for the a/c through a 1200wt inverter because the a/c is 500wt maybe 900wt when the compressor kicks in ? sound do-able?
Old Mar 1, 2011 | 11:01 PM
landyacht318
I don't think you understand how fast a continuous 500 watt load will drain a battery. I don't think the alternator could keep up.
Perhaps if you could plug in the battery and fully charge it every night you could make it work
. Check out this thread
http://www.expeditionportal.com/foru...ir+conditioner.
