97 B2500 Van 5.9 Serpentine Belt Issue
Old Mar 23, 2011 | 02:58 PM
nmt1405's Avatar
nmt1405
Default 97 B2500 Van 5.9 Serpentine Belt Issue
I just replaced the tensioner but I am still getting the squeal. Is there a trick to the groove placement on each pulley? The tensioner was definitely bad. Any suggestions?
Old Mar 23, 2011 | 10:49 PM
stev's Avatar
stev
Just changed the belt and water pump on the van 5.2L. It squealed like a pig being chased for slaughter. I tried the belt dressing, but after the first 1-mile the squeal was back with a vengeance. the alignment looked fine for the pulleys. So, rather than finishing off the can belt dressing, I went with an old garage mechanic's tip. I had coated the outside part of the belt with lithium grease. After three good coatings (one coating for over night), the pig left. Only a mouse squeak exists on cold mornings. When it warmed up to above 74 this week all of the noise went away. The belt still looks brand new and the lithium grease is nowhere to be seen.
Old Mar 24, 2011 | 11:00 PM
Rusty93RamVan's Avatar
Rusty93RamVan
A bad belt tensioner will typically give a "clattering" sound, not a squeal.
Old Mar 25, 2011 | 07:34 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
If the tensioner is weak and not applying enough pressure, the belt slips and squeals.
Old Mar 26, 2011 | 12:29 AM
Rusty93RamVan
Was just commenting on the sound the tensioner itself makes when it goes bad. In any event, he just replaced it so it's unlikely related to the squealing. Probably just a crappy belt.
