1990 B250 brake/turn/hazzard trifecta
NOTES:
headlights - yes
tail lights - yes
parking lights - yes
interior lights - yes
backup light - yes
bulbs - all good
regular fuses - all good
brakelights - no
turnsignals - no
hazzards - no (except when ignition is on and left turn signal is applied, then the left blinks)
I don't know what to check next. I tried replacing the brake switch. I've not been able to locate the relays. This van was parked five years ago with everything working... this is the only issue... engine and all works great.
headlights - yes
tail lights - yes
backup light - yes
bulbs - all good
brakelights - no
turnsignals - no
Hazzard switch , Only reason I created account was to log on and thank the guy that posted that being a issue now i cant find the thread and found your post (it can be stuck in between on and off or bad switch will cause that issue i tapped it as fast as i could 3 or 4 times then had lights still no flash but the lights all worked then replace the flasher and all worked fine
