Gearing for freeway fuel economy
Old May 6, 2011 | 08:08 AM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Originally Posted by burning1
I just ran the numbers for my van...
1986 Dodge ram van:
Tire revs per mile (235/70/15): 720.4
3rd gear ratio: 1:1
Stock Final drive ratio: 3.55
Engine Revs per mile: 2557.42
RPM @ 65mph: 2770.53
Modified Final Drive ratio: 2.76
Engine Revs per mile: 1988.304
RPM @ 65MPH: 2153.996
2770 cruising RPMs seems a little excessive, especially for such a big engine. 2.76 is about the tallest ratio I could find, and seems like it would drop the cruising RPMs to a little more reasonable, but still slightly high 2153.
I would imagine that this would put more load on the transmission and drivetrain at RPM, but it seems like it wouldn't be unreasonable given the loads we're hauling. Anyone have any thoughts?
Also, what about running a good 75w/90 gear oil in the rear diff, rather than the spec 80w140?
I would keep the 3.55 or go to 3.23 gearing. I do not recommend going down to less than 3.23. Though the engine would be turning less there is more strain on the motor and actually consumes more fuel, especially any pre multi-port fuel injection engine. Older carburetor and some early throttle body injection engines will produce extra carbon in the cylinders if the engine was ran at lower RPM under higher loads such as high gear highway cruising.
On a Impala forum I am on many have found that the 2.?? gears which were supposed to help highway mileage actually hurts it worse than going with 3.08 - 3.73 gearing. On these cars optimal gearing is 3.43 over 3.08's.
Old May 6, 2011 | 06:12 PM
burning1's Avatar
burning1
Okay, good to know. Is that experience with the 3 speed, 1:1 final drive? Or is it with an OD transmission?
Old May 6, 2011 | 11:18 PM
Mobile Auto Repair
With older automatic three speeds. Now if you try to add OD on a 2.?? then you will have more strain on the engine and very possible more loss on the mpgs.
Good rule of thumb is to keep the engine near and just below it best torque rpm. Most Magnum series engines make best torque at 2k rpms. Not sure about the older LA engines.
Old Jun 3, 2011 | 01:47 PM
DaDodge's Avatar
DaDodge
Look at the revs per mile change by going to a 235/85/15 highway ribbed commerical tire. That should be about as effective of a change as a diff ratio. You might be really suprised at the result. But don't go any wider, cause that robs horsepower.
