B350 royal 1981 axle 3600lbs or 4000lbs?help
Old May 15, 2011 | 03:53 PM
DRUSS's Avatar
DRUSS
Default B350 royal 1981 axle 3600lbs or 4000lbs?help
Hello I appear I am DRUSS I am French and I am an owner of a dodge B350 of 1981. I have quite a lot of repair of wear as to change my disk of brakes and my shock absorbers. At the moment I try to determine the size of my axle; impossible to know if I rose 3600 lbs, 3800lbs or 4000lbs.
Can use me?
vin: 2B7JB33PXBK255796
gvwr: 7500?
ton2188601?
thx very much
DRUSS
Old May 15, 2011 | 04:00 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Check the driver's door jamb for a sticker. There should be an axle code on it. With this code we can help you figure out which axle you have.
Old May 16, 2011 | 06:19 PM
DRUSS's Avatar
DRUSS
It is exact there is indeed a plate no stiker with for registration:
g.v.w.r: 7500
ton: p2188601
the truck is a B350 royal Extended(maxi wagon)
thanks for your help alloro. I am going to try to send some photos
Old May 16, 2011 | 07:28 PM
alloro's Avatar
alloro
Contact Dodge at the link below and request a Build Sheet. By giving them your VIN, they can give a detailed report of everything that went into building your van, including the axle sizes. Be sure to let them know you are overseas and can not get to a local Dodge Dealer to do this.
http://www.dodge.com/wccsapp/univers...ull&category=R
Old May 17, 2011 | 03:58 AM
DRUSS's Avatar
DRUSS
thanks you very much alloro, i send all information to Dodge.I inform you that I have news
