1987 van 360 motor no fire when starting
Old Jun 28, 2011 | 07:30 PM
les jones's Avatar
les jones
Default 1987 van 360 motor no fire when starting
but when i turn the key back to off it will hit just for a sec.
help thanks
les
Old Jun 28, 2011 | 08:27 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Common symptom for a bad ignition coil. Many auto parts stores will test them for you if you bring it in to them.
Old Jul 1, 2011 | 11:14 PM
les jones's Avatar
les jones
Default still not working
i put a new coil on but its doing the same thing
Old Jul 2, 2011 | 01:22 AM
alloro's Avatar
alloro
Didn't you have it tested before replacing it?
Old Jul 2, 2011 | 03:44 PM
les jones's Avatar
les jones
for $20.00 bucks i just put a new one on. it will fire just as the key is turned back to off
Old Jul 2, 2011 | 09:50 PM
alloro's Avatar
alloro
Check for 12v on the coil's primary wires both when the key in ON and when cranking in the START position. Since you now know the coil is good, it might not be getting power when cranking, but does get power for a split second when the key returns to ON.
