B250 Runs rough and burns rich at idle
Old Aug 2, 2011 | 08:08 PM
Dave123's Avatar
Dave123
Default B250 Runs rough and burns rich at idle
I have a B250 5.9L van, 1985. It runs rough at idle, and burns rich. Any ideas. I put new distributor cap, and wires the plugs were good. When I turn the air conditioning on it almost stalls.
thanks, Dave
Old Aug 4, 2011 | 01:28 AM
stev's Avatar
stev
Is it throwing any codes? Do the key 3X dance and count the flashes.
Are the O2 sensors the original ones? When was the CAT replaced? Is the CAT clogged?
Old Aug 4, 2011 | 01:53 AM
landyacht318's Avatar
landyacht318
stev, it is a 1985. No computer, no 02 sensor.
Replace the plugs, and make sure you did not cross any wires when you changed them. I recently knocked one wire loose on the dist cap and could not even tell with the engine idling. I forget which cylinder it was, but I knew something was up by the exhaust smell, then I heard the ticking when I looked at the dist cap.
Put a timing light on the harmonic balancer and make sure it is within 5 degrees of what the sticker under your hood says
Old Aug 4, 2011 | 11:22 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
High mileage? If so, the timing chain set could be worn.
