Can't shift out of park
Old Dec 6, 2011 | 01:38 PM
wheels316's Avatar
wheels316
Default Can't shift out of park
Hey everyone. I was wondering if anyone has had a problem with their shifter getting stuck. I own a 2001 1500 ram van with the 5.2. I'm a wheelchair user but i do not drive the van...i have someone else drive the van for me. My van was working just fine until i got home yesterday. My driveway has a slight incline and after parking the van, we can't seem to shift it back out of park. We tried everything! We applied the brake and tried shifting the lever down from park but it would not budge. We shook, shifted and tilted the steering column but it wont shift down. I know alot of older vehicles have this problem when the driveway has an incline. We even tried pushing the van up slightly with a truck to see if that would help but nothing. Does anyone have an idea what the problem could be? Any help would be great.
Thanks, Chris
Old Dec 6, 2011 | 08:43 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Are your brake lights working? If not check for a blown fuse.
Turn the key to on but don't start it. Then see if you can shift out of park.
Old Dec 7, 2011 | 04:13 PM
wheels316's Avatar
wheels316
Brake lights seem to be working. I'll have to check if its a different fuse. Is there a separate fuse for the brake/transmission shift interlock?
Old Dec 8, 2011 | 06:17 PM
riverlocks's Avatar
riverlocks
had the same problem with mine last year. the repair shop was able to repair the shifting mechanism. Think the dealer wanted over $200 for a new part.
Old Dec 10, 2011 | 02:07 AM
stev's Avatar
stev
There is a Dodge Recall on the Ram Van for 2001 for not shifting out of park. The BTSI solenoid (blocker assembly) has malfunctioned.
It's covered under this at a no-cost to the owner ... Just call the number below at Chrysler to get a code number and visit your dealer next.
http://www.dealerrater.com/recalls/Dodge/RAM-VAN
2001 Dodge RAM-VAN Recall
Item Affected: POWER TRAIN:AUTOMATIC TRANSMISSION: LEVER AND LINKAGE: COLUMN SHIFT
Date Announced: 12/11/2007
Description of Recall:
ON CERTAIN VAN AND PICKUP TRUCKS EQUIPPED WITH AUTOMATIC TRANSMISSIONS, THE IGNITION/PARK SHIFT INTERLOCK SYSTEM MAY BECOME INOPERATIVE. THIS CAN ALLOW THE SHIFTER TO BE MOVED OUT OF THE "PARK" POSITION WITH THE IGNITION KEY REMOVED (OR IN THE "LOCK" POSITION). THIS CAN ALSO ALLOW THE IGNITION KEY TO BE REMOVED WHEN THE SHIFTER HAS NOT BEEN PLACED IN THE "PARK" POSITION.
Action Needed To Fix It:
DEALERS WILL REPLACE THE GEARSHIFT BLOCKER AND BRACKET ASSEMBLY FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING JANUARY 2008. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Find your local Dodge Dealer.
Hope this helps !
