MPG improvements
Old Nov 12, 2012 | 01:03 AM
  #31
stev's Avatar
stev
Arrow
Originally Posted by Hawkstr
There is a fuel system treatment that Chrysler (per the TSB on the lower plate for the plenum) does. See that the service for it is flat fee $100 at most Chrysler dealers. Helps to remove all the carbon build up. There is a direct line feed, then a tank treatment.
Seafoam. Good product to keep the fuel system and air intake clean.
Also, using gunk motor flush, 1/2 bottle, just before an oil change. I'm doing this twice a year. Running the Purolator L30001 oil filter too.
Old Dec 15, 2012 | 12:50 AM
  #32
jimbo74's Avatar
jimbo74
just adding to this, the fram replacement number (for reference only, as i would never run a fram oil filter) is ph8a
i will be running a ford fl1a, which is hte same size
