2001 dodge 3500 van wont start, fires after cranking
Old Dec 30, 2011 | 09:06 PM
ramseyram99's Avatar
ramseyram99
Default 2001 dodge 3500 van wont start, fires after cranking
I just bought a 2001 dodge 3500 it has the 360. It wont start but when you crank it over it trys after you let the key go. I have several rams so i checked the coil and seems it has a very healthy spark. Checked for fuel at the rail and that seems good aswell. I know in my 99 ram pickup if the battery dies it has to relearn to run at a idle. So that's what I was thinking was wrong with it, we tired to jump start it and cranked very slowly and I knew it wouldn't start cranking that slow with a shot battery but I bought it for $400 so I just loaded it up. Brought it home tossed a good battery in now just cranks like a million bucks but only coughs after cranking it over.
Old Dec 31, 2011 | 12:41 PM
Rusty93RamVan's Avatar
Rusty93RamVan
If the van was sitting for a while you could have some corrosion on the rotor and cap. Check that and clean the contacts carefully with emery cloth if necessary. If the van was sitting for a very long while you could have stale fuel. Give a smell at the fuel filler cap for an odor like varnish or turpentine; if so the gas is bad.
If you have 1/3 tank of fuel or less you may just wish to add 5 or 10 gallons of Premium gas to the tank and just run the old stuff out, otherwise the tank has to be drained of the stale fuel.
Old Dec 31, 2011 | 06:30 PM
ramseyram99
It had sat for about 2 months. Gas is good, and rotor and cap look good. I talked to a buddy he said the coil even though shocked the crap out of my buddy that fell for the hold a bolt in the wire shop joke, might still be bad. So I have another and will try it tomorrow after work
Old Dec 31, 2011 | 11:15 PM
stev's Avatar
stev
Chrysler has a TSB on a topic like this for your 2001 ...
Have you tried the 3X off/on key dance trick for codes? This may tell you what is wrong unless it's TSB-08-24-00 http://dodgeram.info/tsb/2000/08-24-00.htm
Old Jan 1, 2012 | 12:47 AM
ramseyram99
So just cycle the key and it will tell me codes or it resets something?
Old Jan 1, 2012 | 10:35 AM
stev's Avatar
stev
Yes, turn the key 3X back and fourth from off to on (start position) without starting the engine. Leave key to on. Do this within 5 seconds while staring at the trip/mileage odometer. P-codes will display. Pdone means end of codes.
Old Jan 1, 2012 | 04:18 PM
ramseyram99
Changed the coil today and it started right up. I guess having a great visual spark isn't the same as having a strong coil. Thanks everyone
