99 ram van 2500 stalled when driving wont start
Old Jan 11, 2012 | 08:04 AM
1999ramvan2500's Avatar
1999ramvan2500
Unhappy 99 ram van 2500 stalled when driving wont start
Last night, my 99 ram van 2500 with 130k stalled while driving, and wont start, this happened once before and i noticed a blown fuse, replaced it, and van ran fine for over a year, this time fuse is fine. After reading many forum post last night, i suppose i should start today with the trouble code trick, - the 3x on + off and reading odometer, i read also to check coil, cap, rotor, fuel at fuel rail, spark at plugs, etc. Right now the engine basically cranks over, but wont start, i'm not a mechanic, but mechanically inclined, any advise much appreciated, and i will be back to update. thanks.
Old Jan 11, 2012 | 08:08 AM
1999ramvan2500
It's a 5.2l gas engine btw.
Old Jan 11, 2012 | 11:34 AM
1999ramvan2500
update, getting no codes at odometer with the on/of 3 times then leave on thing, pulled a spark plug and layed it close to exhaust manifold, getting no spark, i see what i believe to be the coil near the front of the engine, down halfway, with a 2 wire connector i think coming off the alternator, btw i didnt dis-connect the fuel line, because it appears to be a "push-on" connector and the tubing appears rusty, but i do smell gas in the cylinder.
any ideas on how to test the coil?, i have a multimeter. thanks
Old Jan 11, 2012 | 12:37 PM
landyacht318's Avatar
landyacht318
When you turn the key to on, not start, can you hear the fuel pump run for about 2 seconds?
If not investigate the ASD relay. There is a sticky up top this forum about it.
It controls power to the fuel pump, injectors and coil.
Old Jan 11, 2012 | 12:45 PM
1999ramvan2500
yes, when i turn the key on, not crank, i can hear the fuel pump run for like 2-3 seconds, i'm trying to locate what the resistance in ohms for the ignition coil should be, for a test on that next. anyone know?
Old Jan 11, 2012 | 09:34 PM
1999ramvan2500
removed ignition coil, and did a resistance test on it, the readings were zero on the primary, and fluctuating all over the place on the secondary. went to autozone, purchased and installed a new coil, and started right up. I'm just hoping this is the only problem, and that's what caused the engine to stall dead while driving.
Old Jan 11, 2012 | 10:58 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
A bad coil will do what happened to you. I think you can be quite confident that you've fixed the problem.
