Frame Corrosion Repair
Old Nov 28, 2012 | 07:07 PM
lecygneblanc's Avatar
lecygneblanc
Originally Posted by sparkzz
Congratulations ! Did you do all this in your driveway?
Yes, the van stayed in my driveway. However I worked on the parts in my garage whenever possible because it was getting cold here. My flux core welder did very well in windy condition.
Old Nov 28, 2012 | 07:23 PM
lecygneblanc
Here are some pictures.
This is the driver side horn after I removed the front crossmember beam :
https://picasaweb.google.com/1011130...18683500757506
Whatever is left from the front crossmember beam :
https://picasaweb.google.com/1011130...18692093277538
The driver side horn after cutting the rusted part :
https://picasaweb.google.com/1011130...18676806986050
Test fitting the horn and crossmember assembly with tack welds :
https://picasaweb.google.com/1011130...22551577836882
Crossmember coated with tar-based underbody protection :
https://picasaweb.google.com/1011130...22552007183442
Old Nov 28, 2012 | 08:06 PM
sparkzz's Avatar
sparkzz
Looks like a great job to me. Where did you find the 1/8 steel to do that?
Old Nov 28, 2012 | 08:32 PM
lecygneblanc
I started looking at Home Depot and the others but they only carry thin 1/32 inch metal sheet for body work. I had to go to a local professional metal shop which also sells to the general public in small quantities. The same guy agreed to cut and bend my parts.
I am happy with the end result and I am sure that it is stronger than the vans that have a lot of corrosion in the frame.
