Another issue fixed...on to the Next .........
Old Feb 27, 2012 | 08:17 PM
Gr8lite's Avatar
Gr8lite
Default Another issue fixed...on to the Next .........
Changed the sol & transducer in transmission tonight. Problem solved shifts GREAT! Thanks Guys!
Now onto the next problem.
I need to replace the ignition switch in my 2002 B1500. I believe that it is the all in one mounted inside the column. Any tips , hints or tricks you can share with me??
Thanks!
Old Feb 28, 2012 | 02:24 AM
ComicDom1's Avatar
ComicDom1
Make sure the van is in park and disconnect the negative battery cable. Remove the tilt steering level if you have one, it should pull out. Remove the 2 shroud screws. Your upper and lower shrouds should be snapped together. To get the lock cylinder out your key must be in it. Then rotate it to the start position. If you are changing the whole thing, ignition switch and all then I do not think you have to take out the lock cylinder.
This is from my shop manual for my 1999. There are a few more steps but that will get you started.
Jason
