1992 Dodge b250 plenum replaced
Old Mar 8, 2012 | 07:38 PM
caghosst1's Avatar
caghosst1
Default 1992 Dodge b250 plenum replaced
i just replaced the plenum gasket on my van with the 318 now wont idle and dies as soon as you put it in gear? what did i do wrong?
Old Mar 9, 2012 | 12:21 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Disconnect the battery for 10 minutes, then reconnect it and see if the idle is better.
Old Mar 10, 2012 | 03:29 PM
caghosst1's Avatar
caghosst1
Default i have tried that
when its cold it idles fine but when it warms up it wont idle when the pcm is reset shouldn't the engine light go off?
Old Mar 10, 2012 | 03:47 PM
alloro's Avatar
alloro
Yes, if you reset it with a scanner. Simply disconnecting the battery will not always turn off the CEL. It depends on what code turned it on in the first place.
As to the no idle when hot thing, that can be caused by a bad coolant temperature sensor (CTS). It's the 2-wire(PCM) one, not the one-wire(gauge) one.
